Thinking about it
| posted on 24/5/10 at 08:02 PM |
carb/manifold gasket material
The insulating gasket I need for my carb to manifold is no longer available. It is a plastic type material about 7mm thick and has a fibre gasket
either side. I can get the fibre gaskets no problem.
Does anyone know a supplier of such material or has anyone got any left over?
Im after a piece 70mm x 100mm to make my own.
whitestu
| posted on 24/5/10 at 08:12 PM |
Cheap plastic chopping board from the supermarket?
Not sure it would stand the heat but would fit dimensionally.
RichardK
| posted on 24/5/10 at 08:41 PM |
What carb is it mate, you might get lucky on here.
Rich
Gallery updated 11/01/2011
Thinking about it
| posted on 24/5/10 at 08:49 PM |
Carb is a weber 32/34 DFT from an escort XR3. I have a replacement 34DATR which uses the same gasket and manifold.
RAYLEE29
| posted on 24/5/10 at 10:17 PM |
should be made from phenolic I beleive.
arent most two barrel weber downdraft carbs the same mounting?
should be able to use one from almost any twin choke weber.
Ray
Thinking about it
| posted on 25/5/10 at 05:55 AM |
Ray
But some enter an oval inlet manifold and use an oval insulator. This enters a manifold with two holes so an insulator with two holes is required.
So although the mountings are the same I cant use any insulator.
