blockhead_rich
| posted on 25/5/10 at 02:51 PM |
WTD URGENT > Type 9 clutch fulcrum pin
Hi folks
I've lost my Ford Type 9 clutch fulcrum pin (don't know when or where) and I'm in urgent need of a replacement!!! (It pushes into
the belhousing and the clutch arm locates under it.
It's stopping me getting my engine back in my car!!
Ford will only sell me a minimum of 10 which makes a simple pin and washer b****y expensive!
Ford Pt No. = MF 6022530 (Pin)
and MF 1553790 (washer)
Does any one have a spare or know where I can buy them individually??
Thanks in advance!!
Rich
[Edited on 25/5/10 by blockhead_rich]
blockhead_rich
| posted on 25/5/10 at 03:19 PM |
Ignore my post as I've now found a second hand one, so problem solved!
Pity I've just waisted my two days off though and I had to do some gardening instead !!!!
Rich
Dusty
| posted on 25/5/10 at 05:48 PM |
Glad you're sorted but you can drill and tap for a small bolt and even use a locked nut on the bolt shaft to modify the fulcrum position to
bring the arm forward for zetec or other engines needing a taller release bearing.
