r1_pete
| posted on 31/5/10 at 05:49 PM |
Help with a bit of machining.
Can anyone help me out with a bit of lathe work, I need the centre of my trigger wheel boring out a little, its 150mm dia, and wont fit in my
ML7's chuck.
Alternatively any hints on 'chucking it' for boring.
stevebubs
| posted on 31/5/10 at 05:52 PM |
bolt it to the front pulley and put the pulley in the chuck?
Confused but excited.
| posted on 31/5/10 at 06:06 PM |
Won't it fit in the chuck if you put the jaws in the other way round?
trikerneil
| posted on 31/5/10 at 06:12 PM |
Has it got any holes in it that you can use to bolt it to a faceplate?
Neil
ACE Cafe - Just say No.
r1_pete
| posted on 31/5/10 at 08:46 PM |
Tried the reverse jaws, not quite big enough.
Its a solid wheel, maybe I could drill it for a faceplate.
Will pull the pulley off and have a look, but I wanted to use the centre hole to register it centre on the crank bolt head.
liam.mccaffrey
| posted on 31/5/10 at 08:56 PM |
Have you got a face plate?
2 min job if you have?
Build Blog
Build Photo Album
flak monkey
| posted on 31/5/10 at 08:58 PM |
If you struggle pop it in the post and I'll do it for you for a beer
Sera
http://www.motosera.com
madteg
| posted on 31/5/10 at 09:17 PM |
If you are stuck send it to me and i will sort it.
[Edited on 31/5/10 by madteg]
