Author: Subject: Can someone make this for me?
Miks15
posted on 8/6/10 at 04:39 PM Reply With Quote
Hi Guys,
Can anyone make 2 of these for me?
Image deleted by owner
Cash waiting
gingerprince
posted on 8/6/10 at 04:48 PM Reply With Quote
I assume the dimensions are in miles and it's another large hadron collider?
mcerd1
what material ?
Mr G
posted on 8/6/10 at 04:52 PM Reply With Quote
Originally posted by mcerd1
what material ?
Going by the left drawing..... chocolate That's why he want's 2, so he doesn't have to give away his last one
posted on 8/6/10 at 04:55 PM Reply With Quote
what material ?
ROTFL. quality retro joke
Toniq-r
posted on 8/6/10 at 05:03 PM Reply With Quote
Give Blue Peter a call Im sure they can help Cardboard or Wood
blakep82
posted on 8/6/10 at 05:04 PM Reply With Quote
looks like mm and aluminium to me. so, in answer to his question, can anyone make it for him?
________________________
posted on 8/6/10 at 05:05 PM Reply With Quote
If all else fails if you're prepared to throw money at it Emachineshop is useful (though rather expensive)....
imp paul
posted on 8/6/10 at 05:13 PM Reply With Quote
try flack monkey he should be able to help
Madinventions
posted on 8/6/10 at 05:22 PM Reply With Quote
0.85(mm?) wall section at the bottom, but 1.15(mm?) at the top. Intentional?
The change in diameter over the length is quite mild so could you not flare some tube, or are the dimensions critical?
Ed.
[Edited on 8/6/10 by Madinventions]
View my band website:
http://www.shadowlight.org.uk
Miks15
posted on 8/6/10 at 05:41 PM Reply With Quote
Cheers for all the replies guys.
Sorry for not putting much information, had it all in my head assuming everyone else could read my mind
Its a steering adaptor for escort TRE's to fit in my BMW hubs. So some sort of steel would probably be best.
Yes the different taper is intentional, the escort taper is 1/8 i believe whereas the BMW taper is 1/10 IIRC.
Have sent several u2us to flak but no reply so seeing if someone else will give it a go?
mcerd1
posted on 8/6/10 at 05:49 PM Reply With Quote
ideally you'd need a taper reamer to do the internal bit - normally I'd give this a go, but think my kit won't give you the accuracy you need
however there is a man just down the road from me that does this stuff for a living - so if your stuck I can draw it up properly and get him to make them
(his prices are normally very reasonable)
Miks15
posted on 8/6/10 at 06:02 PM Reply With Quote
cheers for the offer mcerd, will let you know if nothing comes from here
snapper
posted on 8/6/10 at 06:06 PM Reply With Quote
Paul Gooderham AKA 907
I eat to survive
I drink to forget
plentywahalla
posted on 8/6/10 at 06:07 PM Reply With Quote
Best way would be to spin in from tube. Tapered wall would come naturally then.
Googe someone local with a spinning lathe.
plentywahalla
posted on 8/6/10 at 06:11 PM Reply With Quote
Yes ... I know there's an 'L' in Google
t16turbotone
posted on 8/6/10 at 06:37 PM Reply With Quote
would it not be easier to use bmw TRE and adapt to fit escort steering rack?
just a thought
Miks15
posted on 8/6/10 at 06:47 PM Reply With Quote
BMW TREs are really long and there threads are different to the escort rack so i can just use them, so this seems like the best option i can come up with
indykid
posted on 8/6/10 at 08:39 PM Reply With Quote
i was pondering this one last night though not for your specific application. it was for inverting the TRE on an mx5 upright. i came to the idea of machining the steering arm of the upright out to a parallel bore with a small counterbore, then turning a tophat bush with a taper machined into it. the wide end of the taper would be at the brim end of the tophat and a tight clearance fit into the steering arm and bearing locked in place.
making the top hat slightly shorter than the steering arm would mean the washer under the nut would make it all captive in the steering arm and locked tight in place. saves machining a taper on the o.d. but does mean you'd need to machine the upright
tom
posted on 8/6/10 at 08:58 PM Reply With Quote
how about drill the upright out parallel, and then just bolt a good rosejoint onto it? Is the escort rack m12 or m14?
Miks15
posted on 8/6/10 at 10:15 PM Reply With Quote
I believe the rack is m14,
Just woundering if the expense of rose joints are worth it?
Simon
posted on 8/6/10 at 11:44 PM Reply With Quote
What, a tenner or have someone machine something?
I'd go fo taper reamer to start with (as that might be considered the right thing to do), then go for rosejoints (or spherical bearings itwywtct).
Simon
Miks15
posted on 9/6/10 at 12:03 PM Reply With Quote
well itd be a tenner each side, and getting the hubs machined, then the hole would be too big for an M14 bolt so would need an adaptor anyway
mcerd1
posted on 9/6/10 at 12:17 PM Reply With Quote
just looking at your sizes - if the BMW is a 1/10 wouldn't that make the outside dia. of the fat end 16mm not 15.9mm ?
Miks15
posted on 9/6/10 at 10:24 PM Reply With Quote
hhmmm cheers for spotting that mcerd, will double check my sizes when im home for the weekend
