Pdlewis
| posted on 8/6/10 at 08:39 PM |
WTD: R1 5PW
does anyone have a R1 5PW motor kicking about they want to sell as mine has just died on a run out I think its the gearbox which has died but is
prob easier just to replace the motor
Build Photo Album
Updated 05/02/2009
Wheels244
| posted on 8/6/10 at 08:41 PM |
Malc will be your man - as usual.
What happened to it ?
Should I be worried ?
| posted on 8/6/10 at 08:43 PM |
Should have chosen a proper car engine the first time, tisc tisc.....
Pdlewis
I dont know what happened to it and I dont want to look after waiting for 2 hours to be recovered I can only select 2 gears and cant get into nutral
Build Photo Album
Updated 05/02/2009
Wheels244
| posted on 8/6/10 at 08:49 PM |
Bent selector fork ?
I'd contact Malc about rebuilding it - he's not back from Hols until Thursday though.
A lot cheaper than a new engine I would have thought.
| posted on 8/6/10 at 08:53 PM |
Probably the heavy handed gearshift (big lever) buggering the selector forks or even worse the dogs.
They are such delicate little things...
May I suggest a hand operated clutch and foot operated gearshift? Everyone complains the clutch in a bec is a pita, then wonder why the gearbox gives
up the ghost with whacking great gear changes using a massive lever.
I used to hammer the live out of my old Z1000 but changing gear without the clutch was a matter of resting on the gearshift and easing off the
throttle. Clutch was used for downshifting and performing massive wheelies...
Andy B
| posted on 9/6/10 at 07:35 AM |
give me a bell at the unit - I have a short block and possibly a gearbox which gives you 2 options to sort the issue
regards Andy
