Author: Subject: last bits for iva retest
cd.thomson
posted on 15/6/10 at 11:08 AM Reply With Quote
Hi lads, any help with the below?
I would like to buy/borrow/steal some electrical trunking, medium thickness (12-15mm?) and a letter/number stamp.
to get my fog light switch to operate only with main/dip beam where is the best place to take power? Do I need to T off two power lines from both sierra switchgear outputs (dip/main) to the switch?
Could anyone advise the best way to make my gear gaiter IVA-able? Should I just glue a plain leather gaiter onto my grp tunnel?
Craig
Agriv8
posted on 15/6/10 at 11:34 AM Reply With Quote
re gaiter a CV boot can work quite well
regards
Agriv8
40inches
posted on 15/6/10 at 01:06 PM Reply With Quote
Convulated split? how much do you want?
cd.thomson
posted on 15/6/10 at 01:14 PM Reply With Quote
cheers mate, just this minute spent £40 on tubing and rubber beading though .
Craig
40inches
posted on 15/6/10 at 01:19 PM Reply With Quote
Sometimes lifes a bitch, ain't it?
posted on 15/6/10 at 01:20 PM Reply With Quote
I have about 10m of split convolute... if only I came here earlier!
eznfrank
posted on 15/6/10 at 04:30 PM Reply With Quote
For the fog i took the feed off the dip because if you look at the table in the manual the dip is on in every combination they list.
stevegough
posted on 15/6/10 at 04:50 PM Reply With Quote
If you do that, the fog will go off when you are on main beam - you need to take a supply from each as I understand it.
Good luck with your retest, Craig.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
