Author: Subject: Volvo 2002+ AWD or VAG 99-2006 4x4 rear diff
MK9R
posted on 17/6/10 at 07:39 AM Reply With Quote
As title, any condition, although i actually only want the Haldex 4x4 coupling off the front of the diff
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
turbodisplay
posted on 17/6/10 at 07:57 AM Reply With Quote
Judging by your last post you want to use the freewheel unit.
You will have a problem as it seems that the freewheel unit disengages at 25 mph as well as freewheel.
Darren
MK9R
posted on 17/6/10 at 08:03 AM Reply With Quote
Darren
Actually no, its for the same application, but different solution. Currently I supply recon viscous coupling units foir freelander 1's, but trying to create a solut
Ion for selectable 4wd
Cheers Austen
RGB car number 9
www.trackace.co.uk
Volvorsport
posted on 17/6/10 at 04:21 PM Reply With Quote
the volvo unit is quite large and im not sure if the haldex part is actually seperate , it is however in the earlier models , the rear diff , being almost the same as the 960 IRS shared with all the same live axle 940s aswell .
www.dbsmotorsport.co.uk
getting dirty under a bus
