r1_pete
| posted on 18/6/10 at 07:28 AM |
Wtd Scrap MGB distributor
Anyone got an old scrap MGB dizzy they'd like to sell.
When I upgrade the jaguar to EDIS I need to plug the hole where the distributor was, and don't want to cut up a perfectly good distributor, but
still need the bottom drive section to retain the oil pump drive, looking at teh sopecs a B distributor will do me.
MakeEverything
| posted on 18/6/10 at 07:40 AM |
If the distributor is "Scrap" then the drive will be worn. Surely you wouldnt want to put this into the engine??
Kindest Regards,
Richard.
austin man
| posted on 18/6/10 at 07:51 AM |
Have you tried Mec Spec on the way out to Gainsborough ( Gringley on the hill or thereabouts) so not too far away from you, I used to buy MG related
parts for My Austin from them
http://www.mechspec.co.uk/contact.htm
Daddylonglegs
| posted on 18/6/10 at 08:01 AM |
There is a guy down the road from us that sells/restores MGs Spitfires etc. If you like I can give you his details (when I get them) if that's
any help.
He managed to find me a secdond-hand fuel sender for my spitfire fuel tank in the locost.
Let me know.
JB
r1_pete
| posted on 18/6/10 at 08:26 AM |
Cheers, Yes I know Mechspec, will give them a try.
Any contacts usefull.
Its not a drive as such, it has an offset dowel which locates with the mechanism which drives the oil pump, and looking at it the drive mechanism
could ride up without a distributor base holding it down.
Cheers.
Pete.
speedyxjs
| posted on 18/6/10 at 02:30 PM |
Does it have to be MGB? I have an AJ6 dizzy you can have for postage.
cliftyhanger
| posted on 18/6/10 at 03:47 PM |
On spitfires etc I have seen core plugs used to replace the dizzy, though a bit worried it might get pushed up. Also seen plates with spacers under
used to the same effect, with an engine breather attached...
r1_pete
| posted on 18/6/10 at 05:23 PM |
Thanks Speedy, the aj6 is gear driven, the XK is offset dowel.
speedyxjs
| posted on 20/6/10 at 12:40 PM |
Np
