smart51
| posted on 29/6/10 at 02:42 PM |
wanted: very short length of 3" tube
I need a very short length of thick wall steel tube to make a tool. I'm looking for about 70mm internal diameter so 75mm or 3" OD is
ideal with something like a 3mm wall. It doesn't need to be exact. I only need a 20 or 30mm length. Do you have an offcut of old tube you
would exchange for beer tokens? Please U2U.
I'm going to make a hole swaging / flaring tool using 3" pipe welded to a flat plate with a small hole in the centre plus an old hole saw
with a nice rounded shoulder. A big bolt through the middle should hopefully pull a nice shape into some thin sheet with a 50mm round hole punched
into it.
| posted on 29/6/10 at 02:44 PM |
EH??
smart51
| posted on 29/6/10 at 02:59 PM |
EH??
I want a piece of steel tube about 75mm in diameter with a 3mm or so wall thickness. 20 or 30mm in length. Do you have some?
| posted on 29/6/10 at 03:01 PM |
Sorry, I'll have look when I get home. I was taken over by my post count on the last one there 6666
smart51
| posted on 29/6/10 at 03:16 PM |
Here's a pic of what I have in mind. Pull the black hole saw into the grey tube welded to a plate and the hole in the blue sheet steel should be
flared.
If anyone has an old hole saw of the right size and shape, even if it is blunt and useless, I'll pay your postage to take it off your
hands!
rallyingden
| posted on 29/6/10 at 03:28 PM |
Might I suggest you make it like this to prevent the edge of the pipe creasing the panel
RD
I will look for some pipe at work tomorrow
RD
[Edited on 29/6/10 by rallyingden]
smart51
| posted on 29/6/10 at 03:32 PM |
Suggest away. Is the pipe likely to make a circular ring depression in the sheet without the plate at the top? I don't need that. How wide
does the rim need to be to prevent damaging the sheet?
RAYLEE29
| posted on 29/6/10 at 04:46 PM |
Hi, you dont need tube then just get a bit of 1" flat about 3.3 x the dia you want and bend it round a mandrel (anything the right dia)weld it
up and then weld to your pate ive made scroll jigs this way for making gates etc
Ray
PSpirine
| posted on 29/6/10 at 06:14 PM |
The rim only needs to be about a cm but you do need a lip I reckon... I'd be worried about it punching through if you've just got the wall
of the tube pressing into the thin sheet.
| posted on 29/6/10 at 07:12 PM |
Version two definately works better LAst time I needed a small section of tube Merlinmotorsport sorted me out. I did buy quite a few other bits at
the same time so they bunged it in at a very competitive price (I only needed 100mm to make a cast for my wax lathe blanks). Don't ask
(didn't work).
big_wasa
| posted on 30/6/10 at 05:38 AM |
Ive got 40cm in galve you can have gratis.
I havnt got time to get out the hacksaw and post would be dear but if you know of some one passing your welcome to it.
[Edited on 30/6/10 by big_wasa]
| posted on 30/6/10 at 07:23 AM |
I've checked, I don't have any, sorry mate.
Nice idea though, may give it a try when I've finished a couple of the current projects
