matt.c
posted on 29/6/10 at 05:23 PM |
OT: Loft extension?
Can anyone give me a rough idea of how much it would cost to have a loft extension on my normal sized 3 bed bungalow.
I want to add as many rooms as i can get up there.
East anglia area.
I think i will need to get a new roof as mine aint high enough and will need a couple of gable ends knocking down and a couple of new larger ones
built.
I dont have a clue what else is involved as im not great with that sort of stuff. I dont want to go and get proper quote if it is going to cose a
fortune.
Many thanks for any advise you can give me.
Matt
Confused but excited.
posted on 29/6/10 at 05:26 PM |
East anglia area.
built.
fortune.
Matt
I thought I was an optimist !
matt.c
posted on 29/6/10 at 05:31 PM |
Have i asked a "how long is a piece of string" question?
suparuss
posted on 29/6/10 at 05:32 PM |
for a reputable company id say anything from £15k upwards. if you are raising the height of the roof youll definately need planning consent and
probably building regs aproval, although since it is conversion from single to 2 storey will not be as hard as changing a 2 storey to a 3 storey cos
they really go to town on the fire safety.
zilspeed
posted on 29/6/10 at 05:34 PM |
Space provided by an attic conversion is much more difficult to achieve than that provided by a typical single storey extension.
It gives a poor return on your investment comparitively speaking.
Can you build out rather than up ?
AndyW
posted on 29/6/10 at 06:14 PM |
get a proper builder involved to give quotes, speak to local architects to get quotes on the plans, these alone can cost thousands, speak to council
and get quote for planning and building regs. There is no such thing as a cheap option and dont be fooled into thinking there is.
StevieB
posted on 29/6/10 at 06:15 PM |
That's not always the case with bungalows, where the return can be substantial if it's done right.
I've been looking at a loft conversion to make a proper master bedroom and have seen some example costs for a job that needed a roof extension -
it effectivey needed the entire roof removing and starting again - budget was £45k...
My roof has a steep pitch, so there's plenty of scope, though it is a modern house so I would need a fair bit of steelwork to allow me to remove
the rafters.
posted on 29/6/10 at 06:31 PM |
It depends on what kind of roof trusses you have and how you can provide access to the roof space from the ground floor. You will have to supply
support for the weight of anything going up there as well as people. Dormers can provide more floor area as well as windows. Architects fees can be
10% and upwards of the build cost depending on how much time they spend on them and planning and building regulations will definitely be required. The
cost will be proportional to the total area gained and time and materials. It's not going to be cheap.
[Edited on 29/6/10 by Peteff]
zilspeed
posted on 29/6/10 at 06:36 PM |
the rafters.
I wasn't referring to the returns based on selling. I was speaking of cost / M2 to do the job.
A few years back, I built a single storey exension for a friend. For the 20m2 of floor space we provided, including a kitchen, the cost was under
£20,000.
Nowadays, in this part of the world, you can expect to achieve a rate of something like £1,172 / M2 for the same thing.
That's space which is the shape you want it to be and doesn't require stairs to be fitted thereby compromising existing accomodation.
Attics conversions are fine if you have no alternative, but they are not without their issues is all I am saying.
Still, I'm sure matt.c will get something sorted out which best suits his circumstances.
Ben_Copeland
posted on 29/6/10 at 06:46 PM |
Building regs will almost certainly have to be sort and for loft conversions it's worked out by a percentage of the total cost of the build if
done by a contractor. So no chance of doing it on the cheap and getting cheaper rates.
My building regs inspector recon'd most loft conversions are over £25k nowadays. So to take roof off etc is going to cost a lot more and
you'll have to submit your plans to planning first, which is about £150 I think.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
jossey
posted on 29/6/10 at 06:50 PM |
rather than highering the roof, lower the ceilings.
its much cheaper and requires no planning.
if you put the dorma onto a private viewing not public road then you dont need planning either.
be aware of party wall act its a f*ckin pain.
keep it under 50sq meters too.
mine cost under 10k but i did lowering of ceilings myself and the insulation and boarding and electrics.
but was worth it. saved me 17k
was 7.6 meters x 6 meters with a 6 meter dorma at back.
no planning just got structural survey for steels.
[Edited on 29/6/10 by jossey]
panichat
posted on 29/6/10 at 06:57 PM |
Extra problems
We had a necessary loft conversion done which ended up a lot cheaper and less hassle than a house move to a bigger property, but we ran into a lot of
unforseen difficulties with building proposals being passed, work started, then inspectors changing their minds and requiring alterations to the
layouts of the ground and first floors to accomodate emergency exit routes etc. We only got through it because we had a very involved architect who
guided us through the problems. I would hate to have been trying the manage the process myself.
Dave
bodger
posted on 29/6/10 at 08:26 PM |
Just got mine signed off today. Cost me 36k but that's living in the South for you. Still it was a big conversion with en-suite & an office.
Get an architect to draw up plans & submit to council for a permitted development certificate. Rules changed in Oct 2008 so you can do a lot of
things now that would have required planning permission before. There's also things you could do before that now require pp. If you get a
certificate before you start work you shouldn't get any grief off the inspectors provided you comply with building regs.
whitestu
posted on 29/6/10 at 08:33 PM |
Ours was about the same for a 3 bed semi loft in London - gave us a large bedroom and en suite.
Stu
StevieB
posted on 29/6/10 at 08:51 PM |
My neighbours paid £17k for theirs quite a few years ago - that's with modern trusses, steel beams, new floor joists and 3 velux windows.
I have a friend who's an architect and, me being a quantity surveyor, should be able to turn out the plans to satisfy planning for a minnimum
cost. I'm then going to just start doing it pice at a time (though the normal phasing of such a build would be to put the stairs in to alow
easy access, but I'll find a way to cope).
I would much rather have an extension to the ground floor kitchen and dining room, but I have a 3 bed house and a 2nd child on the way - I'm
self employed so I also need a home office so the loft conversion seems logical.
As far as the ground floor goes, I was thinking of a conservatory, but I'm not sure it's not worth going the extra mile for a proper
extension.
