Author: Subject: wanted type 9 prop end or whole prop
doddy
posted on 3/7/10 at 06:53 PM Reply With Quote
hi im after a prop end for a type 9 gearbox
or a complete sierra prop anything will do as it will be cut up to my lenth i have the diff end already
cheers doddy
Mark Allanson
posted on 3/7/10 at 06:55 PM Reply With Quote
What you need is a Capri or Transit prop so you can get rid of the rubber donut but at the front, the diff ends are all the same
afj
posted on 3/7/10 at 06:57 PM Reply With Quote
got one sat in my garage you can have for free but im sure there is someone closer
eerrrrrrrrrrrrrrrr
chris666
posted on 3/7/10 at 07:03 PM Reply With Quote
i got a whole prop what size do u need?
doddy
posted on 3/7/10 at 07:15 PM Reply With Quote
hi i just need the end as im having somone make the rest so as long and the whole gearbox end is ok
chris where are you how much do you want for it
afj would you send it in the post im happy to send you money to cover postage and a drink for you
cheers doddy
chris666
posted on 3/7/10 at 07:30 PM Reply With Quote
Really i want as much as possible.what are you willing to pay?
I live in wrexham,i would post.
Chris
alexg1965
posted on 3/7/10 at 08:19 PM Reply With Quote
I have a prop from a 2WD Sierra Cosworth and I think it's the same input shaft. You're welcome to all of it or bits of it if you want. I was only going to take it to the tip anyway.
Alex
bigpig
posted on 3/7/10 at 08:37 PM Reply With Quote
I've got a whole prop in the garage that is going to the tip, if someone doesn't pick it up.
I don't think I could post it, although it would be funny to wrap it up in brown paper and post it to the reptile section of the local zoo
ChrisW
posted on 7/7/10 at 09:50 PM Reply With Quote
I've got a shortened prop with type 9 one end and Sierra flange the other.
Don't know how long, but it was used in my Viento when I had a type 9 in there. Could measure it if you're serious.
£20 collected from SL9.
Chris
