Author: Subject: Rose joint insert supplier
mcg
posted on 20/7/10 at 11:11 AM Reply With Quote
Hi - I am struggling to find an insert for a rose joint that I have. Anyone know of any good (helpful) suppliers.
I would upload some pictures but I dont seem to have the option on the 'post new topic' form that I am filling out.....errr? Probably being an idiot, but have uploaded pics in the past with no probs.
Any help would be greatly appreciated.
Matt
Many thanks
loggyboy
posted on 20/7/10 at 11:15 AM Reply With Quote
Ive used McGill motorsport via ebay.
posted on 20/7/10 at 11:47 AM Reply With Quote
At the very least you need to specify the thread pitch and diameter and the OD of the insert you require.
mcg
posted on 20/7/10 at 12:08 PM Reply With Quote
Still cant get the pic up so I'll try to describe:
The insert is a reducer and also a spacer.
Spacer portion OD 20mm, ID 10mm, length 11mm.
Insert portion (goes inside the rose joint) OD12mm, ID 10mm, length 15mm
Would be so much easier with a picture!!
Thanks for the help.
mcg
forgot to mention - No thread needed.
posted on 20/7/10 at 12:20 PM Reply With Quote
Off-Road Armoury I'm saving up for some of these beauty's!
minitici
posted on 20/7/10 at 03:44 PM Reply With Quote
Are these what you require?
McGill Motorsports
mcg
posted on 21/7/10 at 08:37 AM Reply With Quote
could be - was in touch with them yesterday. need to confirm the dimensions on the 'spacer' part.
Was thinking of machining one down on a lathe - is there a potential issue with material strength?
minitici
posted on 23/7/10 at 04:56 PM Reply With Quote
No material strength problem if there is a good close fitting hight tensile bolt through the middle!
PS - I'm sure that you could machine a better fitting bush than the one stocked by McGill - but theirs are handy and cheap
[Edited on 23/7/10 by minitici]
smart51
posted on 23/7/10 at 05:18 PM Reply With Quote
If their bush is slightly loose, smear the surface with permanent thread lock and push into the bearing. Once set there will be no play. I saw a machinist blank up a hole he'd drilled too large do this once. When it had set, he drilled the insert without it coming loose.
