Bumble
| posted on 21/7/10 at 02:43 PM |
Wanted.....wing Stays for Cortina Uprights
As above has anyone got any lying around surplus to requirementsan looking to sell??
I see both Aries and Rally Design both do them for the Cortina and are priced around the £45 mark. Any comments on which is the better quality /
stronger?
Thanks,
Matt
big_wasa
| posted on 21/7/10 at 03:06 PM |
Gbs at Newark had some for around £30.
They are a book design and need beefing up a bit. They do fit, the rally design ones did not.
try Matt @ Pro-comp his work if he has the time to make you some.
big_wasa
| posted on 21/7/10 at 07:50 PM |
Did you get some inserts for your cam cover ? I found some in my tin if you need them.
Bumble
| posted on 21/7/10 at 08:49 PM |
Cheers Wasa.....got the inserts for the Cam cover from R1 Pete.....
What's up with the Rally Design stays??
Matt
big_wasa
| posted on 22/7/10 at 12:23 PM |
They dont fit. They are to heavy and still only 3mm x 25mm in the place they all break.
