r1_pete
| posted on 9/8/10 at 10:21 AM |
Wtd, SU HS8 Carburettor
Bit of a long shot I know, but in my quest to avoid ebay, does anyone have an SU HS8 carb kicking about? its 2" choke, with seperate float bowl,
and pipe across to the main jet.
| posted on 9/8/10 at 11:06 AM |
those were relatively rare, e-type and other jags used them from what I recall.
good luck in your hunt - I have the SU and Burlen catalogues should you need asny info..... although the burlen (they took over SU carbs)website is
quite comprehensive.
