Author: Subject: Sytec Hose Clips
m8kwr
posted on 15/10/10 at 07:37 AM Reply With Quote
Sytec Hose Clips
Hi, I am looking for a Silver Sytec Hose clip, it is to go over an 18mm hose.
Demon Tweeks only sell a 10mm one, and ones on ebay are not silver.
Does anyone know where to get these from?
daviep
posted on 15/10/10 at 08:53 AM Reply With Quote
Is 18mm the ID or OD of the hose?
m8kwr
posted on 15/10/10 at 09:02 AM Reply With Quote
Outside Diameter - 18mm (or could be 17.5)s
Its just braided fuel hose.
daviep
posted on 15/10/10 at 09:08 AM Reply With Quote
Check HERE page 26. dash 8
Looks like only silver and blue are available in the larger sizes see HERE is the same.
Could try CBS but they are a bit pricey.
Davie
m8kwr
posted on 15/10/10 at 09:19 AM Reply With Quote
daviep many thanks for your help - cbs are really expensive are I require 18-20 of them
posted on 15/10/10 at 11:15 AM Reply With Quote
Having tried them in the past I never found them that satifactory in terms of both looks or function.
Another way to finish the hose is use heat shrink tubing over the cut end (shrink with a hair dryer) with a good quality fuel hose clamp over the top.
