Author: Subject: Waterproof Se7en cover
stevegough
posted on 8/11/10 at 10:38 AM Reply With Quote
Ideas / info / links for a cover to keep the cockpit dry on the way to IVA (car will be on a trailer...)
Don't really need an all - over, because the car will live in the garage 97% of the time...
Thanks, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
dhutch
posted on 8/11/10 at 10:46 AM Reply With Quote
You can get cockpit covers. I have a tonnue on my so would use that.
One of the most important things is to make sure its not going to rub/chafe on anything as if its flapping against body work it will make a mark even just during a half hour 60mph stint.
How about a grotty duvet and a 6ft square bit of tarp!
Daniel
big_wasa
posted on 8/11/10 at 11:17 AM Reply With Quote
Press studs are a no no for Iva and anything just lashed over will scratch the body work.
Macbeast
posted on 8/11/10 at 11:50 AM Reply With Quote
I plan to use a boot protector cover thing from Halfords. Plastic with loops at the corners so could use bungees to secure
marcjagman
posted on 8/11/10 at 11:54 AM Reply With Quote
Why bother? it's their arse that's going to get wet.
Guinness
Indy Roof Up
Indy Roof Up
But then I am a bit cheap.
If I was travelling any distance on a trailer, tended to put a heavy duty dust sheet down first, then a tarp.
I have a luxury one of these WESTFIELD, CATERHAM, SEVEN TYPE, KIT CAR COVER on eBay (end time 13-Nov-10 23:07:02 GMT) now.
HTH
Mike
Daddylonglegs
posted on 8/11/10 at 12:25 PM Reply With Quote
If the 'other car' in the picture is yours then you should be able to afford to get the car transported in a padded, climate controlled trailer!
stevegough
posted on 8/11/10 at 12:48 PM Reply With Quote
Thanks to all of you - I have just bought what Mr 'Liffey water' (Guiness) suggested which is exactly what I was after.
Cheers, guys.
Luego Locost C20XE.
Guinness
posted on 8/11/10 at 02:27 PM Reply With Quote
It was bloody difficult to find a towbar that fitted the Aston
Me = Builder = MK
Him = Architect = Aston
jacko
posted on 8/11/10 at 04:59 PM Reply With Quote
This is my home made cover it was a cover i bought from Lidl and cut it down to fit under the bonnet
Jacko
home made rain cover
