Author: Subject: Drum brake assembly and build wheels (114.3*5)
Badger_McLetcher
posted on 15/11/10 at 08:24 PM Reply With Quote
Hey guys, I'm in need of a set of drum brakes which I can use for the handbrake on my project. Basically the disks I'm intending on using for the rear axle have a drum inside for the handbrake, and muggins here threw the gubbins away a long time ago
The drums are 170mm dia, 40mm depth and I'm really just after a shoes/mounting assembly that I can adapt to fit my purposes! Of course if anyone has a 300zx handbrake assembly lying around that'd do nicely
To save me posting again I'm also after a set of build wheels, any size, but they must be 114.3*5 PCD- it's only so it's moveable when I get the suspension done
I'll pair a fair price for either of these things, but being a pennyless student the cheaper the better
Cheers!
Badger
If disfunction is a function, then I must be some kind of genius.
posted on 15/11/10 at 08:47 PM Reply With Quote
Badger,
I have a full set of 1.6 Sierra drum brakes and another full set of 2.0 Sierra drum brakes available, the former being slightly smaller dia and narrower (can measure if you need me to) than the latter.
U2U if I can help.
Nick
Badger_McLetcher
posted on 15/11/10 at 10:05 PM Reply With Quote
Hey Nick, thanks for the offer but I think the sierra shoes are a bit large for the drum on the disc. Ta very much for replying though
posted on 15/11/10 at 10:22 PM Reply With Quote
No problem!
