Author: Subject: Carb / TB balance meter
RazMan
posted on 26/11/10 at 05:01 PM Reply With Quote
I'm looking for the hand held type which you basically stick in the TB bore and make a reference measurement. I know I have seen them but can't find anything on eBay.
Raz
marcjagman
posted on 26/11/10 at 05:15 PM Reply With Quote
Halfords, about £9 or Brown Brothers if you have one near you.
SPYDER
posted on 26/11/10 at 05:20 PM Reply With Quote
Go on fleabay and search "synchrometer"
I use one of this type and can recommend it.
Geoff.
stevebubs
synchrometer ...
RazMan
posted on 26/11/10 at 05:41 PM Reply With Quote
Bingo! So THAT is what they are called - not cheap are they
Thanks guys
*edit* Ah bugger - it might be too big for my teeny weeny bores which are 35mm. Can anyone tell me if it will bodge down a bit smaller than the specified 40mm?
[Edited on 26-11-10 by RazMan]
Raz
INDY BIRD
posted on 26/11/10 at 05:44 PM Reply With Quote
hi i am sure i still have one in the garage if you want to borrow it??
i am near finchingfield essex about 45 mins from you,
cheers
sean
RazMan
posted on 26/11/10 at 06:34 PM Reply With Quote
Sean, you are an absolute STAR!
I think I can get it to fit my trumpets instead of the throttle body so it should do the trick - setting up 12 of the little blighters is proving to be a bit of a challenge
Raz
stevebubs
posted on 26/11/10 at 06:38 PM Reply With Quote
Thanks guys
Should be able to do this with a bit of rubber pipe or sommat - basically you want the airflow to go through the synchrometer...you just need to figure out how to stop it entering through any other route...
[Edited on 26/11/10 by stevebubs]
RazMan
posted on 26/11/10 at 11:25 PM Reply With Quote
My trumpets should be arriving next week so I think it will fit them nicely.
Thanks to INDY BIRD it looks like I don't need to buy one after all
Raz
