Author: Subject: wtd: exhaust studs, 55mm long?
blakep82
posted on 28/11/10 at 07:13 PM Reply With Quote
i need some exhaust studs do to my new spaced out exhaust, but i can't seem to find anywhere to buy them. the only ones i can find are £2.50 EACH! can't remember the thread on them, its either m6 or m8, its a vauxhall 2ltr ectoec if anyone knows the answer to that one
________________________
splitrivet
posted on 28/11/10 at 07:43 PM Reply With Quote
Easy get some set screws or threaded rod and cut it/them down to length.
Bob
blakep82
posted on 28/11/10 at 07:46 PM Reply With Quote
are they actually ok to do that way? i thought of it, but didn't know if there was some heat treating on them, or if they were hardened or something?
splitrivet
posted on 28/11/10 at 08:30 PM Reply With Quote
No just standard steel, its what I've always done for the last 40 odd years and never had a problem.
Bob
blakep82
posted on 28/11/10 at 08:35 PM Reply With Quote
cool, i'll do that them what about brass nuts? why are they always used?
splitrivet
posted on 28/11/10 at 08:43 PM Reply With Quote
They used to use them so they dont seize on the stud but modern manufacturers dont bother so why should you.
Bob
blakep82
posted on 28/11/10 at 08:46 PM Reply With Quote
my engine whis is only 12 years old now, that has brass nuts
posted on 29/11/10 at 12:57 PM Reply With Quote
Best to cut the studs from A2 stainless steel studding. another good trick is to use studding extender/joiners/connectors as nuts.
Studding joiners are very deep nut about 8 times the depth of a normal nut this covers the exposed hread of the stud gives you a much better chance of getting the nut off after it has been on a few years.
Do an ebay search on "Studding M8 stainless"
[Edited on 29/11/10 by britishtrident]
