Author: Subject: Air horns/trumpets
cliftyhanger
posted on 14/12/10 at 06:16 PM Reply With Quote
Air horns/trumpets
Wanted, 4 air horns/trumpets with dellorto/jenvey type bolt on fittings.
45mm diameter, and 25mm or so deep (I have some longer ones at 50mm and 65 mm if anybody wants a swap )
Anything lurking in the garage?
Clive
[Edited on 14/12/10 by cliftyhanger]
minitici
posted on 14/12/10 at 06:50 PM Reply With Quote
Title had me thinking of Colonel Bogey
Dusty
posted on 14/12/10 at 09:04 PM Reply With Quote
I've a spare set from jenvey at 40 mm long. Not quite what you need, but shorter than 50 or 65.
cliftyhanger
posted on 14/12/10 at 10:44 PM Reply With Quote
Afraid still a tad too long K+N's I will be using are the 63mm deep ones, so allowing for a fit of shrinkage 20mm clearance will be a little too tight.
It's a shame, because I was all ready to put something around 100mm deep on, until I remembered I needed a clutch pedal
