Author: Subject: how to attach coolant hose
chesney321
posted on 2/1/11 at 08:21 PM Reply With Quote
am running the lower coolant hose along the bottom of the chassis on a fireblade engined car..any ideas of how to attatch to the chassis..25 mm bore hose.any help greatfully appreciated
omega0684
posted on 2/1/11 at 08:25 PM Reply With Quote
big cable ties will do
chesney321
posted on 2/1/11 at 08:29 PM Reply With Quote
thank you just didnt know if they would cut into the hose.
big_wasa
posted on 2/1/11 at 08:32 PM Reply With Quote
You can get rubber lined P clips that size.
daniel mason
posted on 2/1/11 at 09:22 PM Reply With Quote
Can you cable tie fuel lines also?
40inches
posted on 2/1/11 at 09:32 PM Reply With Quote
P Clips every 300mm, although 200mm is better
blakep82
posted on 2/1/11 at 10:27 PM Reply With Quote
i've got a redundant bracket on my car in the engine bay, i've P cliped my lower cooling hose to that.
fuel lines will also be P clipped
________________________
posted on 2/1/11 at 11:23 PM Reply With Quote
Don't clip it too rigidly you have to allow for engine movement.
