RichardK
| posted on 2/1/11 at 11:18 PM |
Wanted:Thermostat housing to head seal
Does anybody know the part number if this please as I reckon I need one as I can see what looks like pink crystals all around my assy.
If anybodys got a spare one or knows if its just a normal O ring and know the size even better!
Rich
Item to the right
Found it 1092262 if anybody else needs it!
[Edited on 2/1/11 by RichardK]
Gallery updated 11/01/2011
austin man
| posted on 2/1/11 at 11:35 PM |
is it for a blacktop zetec ? if so local motor factors should havve them, on the downside the housings are known to crack. Just hope it is the seal
RichardK
| posted on 2/1/11 at 11:44 PM |
Yes it is for a blacktop, dont suppose you know if they crack by themselves or when they are removed?
Rich
bbwales
| posted on 3/1/11 at 12:55 AM |
Just found that mine is cracked, it is on the seam so I will be of to the Main Stealers to get a new one on Tuesday.
Regards
Bob
indykid
| posted on 3/1/11 at 01:02 AM |
on my mum's mondeo, it was the inner lip that disintegrated so there was no support for the square section o ring, causing it to leak from the
mating face. silicone wouldn't cure it, but a replacement from the scrappers did (it's not removing them that cracks them)
tom
[Edited on 3/1/11 by indykid]
