Author: Subject: Exhaust bobbin but with a long thread length?
RichardK
posted on 9/1/11 at 02:34 PM Reply With Quote
It would be real nice if I could find a bobbin that is long enough to go through a bit of 25mm box and still be able to get a nut on, I'm could try and weld a bit of stud on the one I already have while the bobbin is under water as a last resort, but would prefer the real deal so my exhaust can isn't relying totally on my dodgy welding
Anybody if any car had such a beast?
Rich
Gallery updated 11/01/2011
RazMan
posted on 9/1/11 at 02:44 PM Reply With Quote
Can you bolt a bracket to the box section and then bolt the bobbin to that? All the bobbins I have used in the past have short studs and I don't think anything butt welded on will be very strong.
Raz
MkIndy7
posted on 9/1/11 at 03:04 PM Reply With Quote
Could you not tap a thread in the 25mm box (or atleast in the wall of the box) then Loctite the bobbin in. Pretty sure thats what ours is like.
907
posted on 9/1/11 at 03:05 PM Reply With Quote
I have seen bobbins with a male thread one side and female the other.
You can then use a bolt or length of studding whatever size you like.
Paul G
edit to add example. ebay number 160525611702
[Edited on 9/1/11 by 907]
posted on 9/1/11 at 05:09 PM Reply With Quote
"Rivnut" springs to mind, or if not strong enough a weld in threaded tube.
RichardK
posted on 9/1/11 at 05:21 PM Reply With Quote
Yep, ended up knocking a threaded insert up, jobs a good un!
Rich
paulf
posted on 9/1/11 at 10:04 PM Reply With Quote
I had a side ways on exhaust mount and had problems with it vibrating and snapping regularly with the normal mini type bushes .Eventually I bolted a plate through the floor so that it stuck out the side and used a heavy duty rubber mounting bush mounted vertically and have no problems since.The bushes are available from RS components and are available in various sizes with male or female threads, I used one about 35 mm dia with 10mm female threads and used a short bolt in each end.
Paul
