Author: Subject: Sierra Ignitian Parts
Dan.
posted on 23/1/11 at 09:43 PM Reply With Quote
Hi All does anyone have a coil and HT leads laying around they dont need, I have a 2.0 pinto without EFI, I have the distributor and cap on the engine but leads are damaged and coil missing.
Silly question but i know nothing about carbed engines.... Is a lift pump required for the fuel or is the mechanical pump one the engine all that is required? if it is required will this do the job? Genuine Ford Sierra/Granada - Fuel Pump - NEW on eBay (end time 02-Feb-11 15:54:07 GMT)
mookaloid
posted on 23/1/11 at 09:52 PM Reply With Quote
The mechanical one should be fine on it's own. it's all the car had before.
MakeEverything
The mechanical pump should do the job for a carburettor engine IMO.
Kindest Regards,
Richard.
Dan.
posted on 23/1/11 at 10:00 PM Reply With Quote
thanks guys wasnt sure if they ran a lift pump or not but that saves a few pennys as its only a temporary engine anyway if anyone has a coil and/or HT leads let me know failing that a link to ebay with some that will fit would be appreciated, Is there anything else I might need?
[Edited on 23/1/11 by Dan.]
