Author: Subject: handbrake cable wanted
tony-devon
posted on 1/2/11 at 03:54 PM Reply With Quote
as per the title, Im suffering as I havent a clue what my rear calipers are from, model or year, so none of the shops will help, and as Im going to cut it up and modify it anyway its a waste
so has anyone got a 2nd hand cable they no longer need hanging around in the garage?
sierra rear end, disc brakes, but no idea of the year, I beleive the car they came from was a 4wd twin cam model?? solid discs about 250-260mm dia
thanks
in theory I thought this would fit?
Ford Scorpio Granada Scorpio Handbrake Cable . New on eBay (end time 06-Feb-11 13:02:07 GMT)
would have assumed they all had disc rear brakes, but the ends look wrong, mine were plastic loop things, sadly the breaker just cut through the existing cable so it was of no use to me.
[Edited on 1/2/11 by tony-devon]
heavy is good, heavy is reliable, and if it breaks, hit them with it
daniel mason
posted on 1/2/11 at 04:15 PM Reply With Quote
put up a picture of the calipers mate. may be able to suss it out then and get the correct item.
macc man
posted on 1/2/11 at 05:56 PM Reply With Quote
I have one that will probably do the job. It is brand new from a rear disc braked sierra. Cost me £20. Yours for £15 posted.
