Author: Subject: sierra lsd
whitstella
posted on 1/2/11 at 04:22 PM Reply With Quote
sierra lsd
hi i'm after a lsd for my kit car is there any out there?????
cheers
mcerd1
posted on 1/2/11 at 04:29 PM Reply With Quote
which type of diff / driveshafts have you got just now ?
Dopdog
posted on 1/2/11 at 05:11 PM Reply With Quote
7 or 7.5 ? which one do you need
whitstella
posted on 1/2/11 at 10:40 PM Reply With Quote
lsd
hi i currently have nothing just getting some parts together so just putting the word out there to see what came back. i'm building a haynes so which diff would be best????
cheers
mcerd1
posted on 1/2/11 at 11:23 PM Reply With Quote
there are 2 sizes 7" and 7.5" - the 7.5" is too big for some chassis, but if your building your own then you should be able to make either fit
all the ford LSD ones all have bolt-on driveshafts (but not all the diffs with bolt-on shafts have LSD's)
the 4x4 cossie's / XR4x4's have 7" diffs (with 100mm CV joints)
the 24v granada cossie's have 7.5" diffs (with 100mm CV joints) - but only cars without traction control have LSD's
the 2wd sierra cossie's have 7.5" diffs with larger driveshafts (108mm CV joints) - so these need the hubs to match
these are often easier to find as not as many kit cars can use them
[Edited on 1/2/2011 by mcerd1]
