blakep82
| posted on 6/3/11 at 10:49 PM |
could someone make me one of these please?
nothing too complicated, just a 35mm pipe, with a 16mm take off.
16cm long, with the take off 5cm from one end, like the photo below
awesome cheers
________________________
MakeEverything
| posted on 6/3/11 at 10:56 PM |
Just use one of these (The bottom fitting)
  Coolant Pipes 3
32mm end feed copper Tee.
Kindest Regards,
Richard.
blakep82
| posted on 6/3/11 at 11:00 PM |
in need 35mm though, and i prefer aluminium to keep in with the rest of the system.
where did you get them from, and i'll have a look to see what they have
welderman
| posted on 7/3/11 at 02:00 AM |
If I have enough bits I will make one tomorrow
Thank's, Joe
I don't stalk people
blakep82
| posted on 7/3/11 at 11:58 AM |
awesome thanks Joe
welderman
| posted on 7/3/11 at 12:30 PM |
Righty
ive not got the 35mm, but do have 38mm and 16mm would it push over the hose ?
I could pssibly turn the end down a little if it were to help, maybe down to 36.55mm ish/ish/fraction lol.
Thank's, Joe
blakep82
| posted on 7/3/11 at 12:49 PM |
it won't stretch to to 38 unfortunately already tried that as my radiator is 38mm, the engine is 35mm
hmm, can you put beading round the pipes? if you can, i've got a few other pipes i'm using for plain hose joiners, they could really do
with beads on them, and i've got some more 35mm pipe in the garage i could maybe send down to you if you could do them?
