Author: Subject: 3.14 diff
phil clegg
posted on 7/3/11 at 10:45 PM Reply With Quote
3.14 diff
wanted 3.1 diff .thanks
Mr Whippy
posted on 7/3/11 at 11:36 PM Reply With Quote
but for what? sierra, altas, cortina??
blakep82
posted on 7/3/11 at 11:43 PM Reply With Quote
i imagine for sierra= good luck lol
some BMWs have similar ratios. the diff is heavier though. look at E36 beemers
________________________
Mr Whippy
posted on 7/3/11 at 11:55 PM Reply With Quote
there's a sierra diff on ebay but no idea what ratio it would be. Even a second hand one should be ok as the damage to the diff in my live axle has occured due to rust scales in the bearings which would not happen with the sierra alloy case, he says...
Ford Sierra Cosworth 2 Wheel Drive Rear Differential on eBay (end time 07-Apr-11 00:07:03 BST)
These guys have been very helpful to me and sourced parts for my axle. They may be able to help you out
linky 2
[Edited on 8/3/11 by Mr Whippy]
trikerneil
posted on 8/3/11 at 04:21 AM Reply With Quote
ssc28 on here was selling a 3.14 Sierra diff - £225 LINKY
HTH
Neil
ACE Cafe - Just say No.
mcerd1
posted on 8/3/11 at 10:08 AM Reply With Quote
thats a 7.5" diff (you can tell by the top mountings)
and from a 2wd cossie it should be a 3.64 LSD with the larger 108mm CV joints - but there is no way to confirm its an LSD or what ratio it is from that add.
[Edited on 8/3/2011 by mcerd1]
mcerd1
posted on 8/3/11 at 10:13 AM Reply With Quote
see his last post:
Originally posted by ssc28
Diff and TB's now sold along with much more
trikerneil
posted on 8/3/11 at 04:41 PM Reply With Quote
Oops! sorry, 'twas obviously a bit too early for me.
Neil
phil clegg
posted on 8/3/11 at 10:54 PM Reply With Quote
3.14 diff
sorry should have said for a sierra diff and how can i tell if its a 7 or 7 and a half inch ,it has lobros and a lots of plates stuck together,what type of lsd is this
mcerd1
posted on 9/3/11 at 06:12 PM Reply With Quote
^^ have you got a picture of it ?
phil clegg
posted on 9/3/11 at 08:31 PM Reply With Quote
diff
after much searching i am now sure its a viscous diff ,i think it has had extra plates fitted which has made it almost solid ,i am removing some but how many,if i knew how many they had as standard thats how many i would put back otherwise i will guess refit and roadtest,if still to tight i will do it again,no choice..
mcerd1
posted on 9/3/11 at 09:06 PM Reply With Quote
the viscous bit is a sealed unit on the ford ones - it sounds like you might have a plate style LSD like a tran-x (or a gripper)
and as far as I know you can't add extra plates to them - instead you change the ramp angles to tune them
here's an example of a tran-x one: linky
the viscous one hardly looks any different to the open centred ones: Ford LSD
to re-tune a viscous one you'd normally need to get the sealed bit refilled with a different spec of fluid
[Edited on 9/3/2011 by mcerd1]
blakep82
posted on 9/3/11 at 09:11 PM Reply With Quote
and as said in your other thread, DON'T just remove some of the plates. setting up is quite a procedure. don't know the ins and outs of it, but if you think you can just remove some plates to free it up, have a specialist do it!
DixieTheKid
posted on 20/3/11 at 07:08 PM Reply With Quote
ive got a 3.14 with lobro joints 7.5" but if im going to sell it your have to make me a good offer! Its mint condition machinally......
COS IT'S Worth IT
