Author: Subject: wanted R1 engine kit
chicade
posted on 16/3/11 at 01:03 AM Reply With Quote
As above R1 engine kit wanted 5JJ OR 5pw full kit including clocks
[Edited on 17/3/11 by chicade]
Yazza54
posted on 16/3/11 at 07:17 AM Reply With Quote
Is this to replace a knackered engine? You realise the 5jj and 5vy are totally different motors?
5jj and 5pw are very similar, if you already have a 5jj I think the 5pw would replace it easier
I'm unhappy cos I eat and I eat cos I'm unhappy
big_l
posted on 16/3/11 at 08:19 AM Reply With Quote
I have a 5jj engine kit spare it's a cracking motor all stuff to make it work call 07737814426
Check out my blog mnrvortxhayabusa@blogspot.com
chicade
posted on 16/3/11 at 11:23 AM Reply With Quote
5JJ 5PW 5VY any will be ok at the point in the build where i am able to have either
chicade
posted on 16/3/11 at 11:25 AM Reply With Quote
think would prefer later inj type engine for the few extra pony's!
Yazza54
posted on 16/3/11 at 11:31 AM Reply With Quote
Different ways of looking at it 5pw better torque and gearing so I've heard compared to 5vy.
5pw is the first injection model
[Edited on 16/3/11 by Yazza54]
chicade
posted on 16/3/11 at 11:41 AM Reply With Quote
5vy bit more power? compared to 5pw?
Yazza54
posted on 16/3/11 at 11:47 AM Reply With Quote
Yes, not sure how much more. But the gearing and power band with the 5pw is better suited to a BEC in my opinion.
Don't get carried away with peak power figures, a 130hp blade engined car will still be mental. I know someone who had a fury with a 893 blade and now has a Phoenix with a 5pw r1 and said there's barely anything in it factoring gearing and setup etc in.
chicade
posted on 16/3/11 at 09:26 PM Reply With Quote
5PW sounds the way forward power commander, air filter and a good set up should be good fun!
adithorp
posted on 16/3/11 at 09:49 PM Reply With Quote
Don't believe them! More power and more revs wins.
Hobbsy is probably the man to ask. His car is 5PW and he rode in mine (5VY) for a few days when his broke in the Alps last year. He's probably best placed to compare.
http://jpsc.org.uk/forum/
TimC
posted on 16/3/11 at 09:59 PM Reply With Quote
From what I've seen in RGB, a 30kg heavier car with 5VY engine performs the same as the lighter car with 5PY. In other words the power advantage of the later engine is worth the same as 30kg weight advantage.
(Thanks Adi )
[Edited on 16/3/11 by TimC]
chicade
posted on 16/3/11 at 10:20 PM Reply With Quote
so anyone got a 5pw engine kit for sale? after complete kit with clocks
Yazza54
posted on 16/3/11 at 10:57 PM Reply With Quote
Originally posted by TimC
From what I've seen in RGB, the 5VY has about an equivalent of a 30kg weight advantage over the 5PW based on Paul Rogers at 537kgs and Josh Smith at 567kgs - massively closely matched.
Thats clearly car and driver weight so not remotely related to the engine weight :/ they're not all built the same, nor are the drivers!
30kg is nearly half what a 5pw motor weighs!
adithorp
posted on 16/3/11 at 11:03 PM Reply With Quote
What he means is the 30kg heavier car with 5VY engine performs the same as the lighter car with 5PY. In other words the power advantage of the later engine is worth the same as 30kg weight advantage.
Yazza54
posted on 16/3/11 at 11:15 PM Reply With Quote
Ah my bad!
Well yeah, on track maybe when it's getting that power screwed out of it every gearchange
TimC
posted on 16/3/11 at 11:42 PM Reply With Quote
Thanks Adi - I was trying to do three things when I wrote that nonsense!
chicade
posted on 17/3/11 at 09:12 AM Reply With Quote
bump
