Author: Subject: Volvo 340/360 Diff-gearbox
Neville Jones
posted on 27/3/11 at 11:05 AM Reply With Quote
Hi All,
For my next project, I'm after
Volvo 340/360 auto diff assembly
Volvo gearbox(that bolts onto the diff.
I'd also like the rear driveshafts as well.
Nev.
Volvorsport
posted on 27/3/11 at 01:58 PM Reply With Quote
you want the CVT box ?
feckin huge .....
diff is located on the back of the manual box , on the cvt its part of an angle drive gear .
www.dbsmotorsport.co.uk
getting dirty under a bus
Neville Jones
posted on 28/3/11 at 11:50 AM Reply With Quote
I want a manual box and diff firstly.
I'm told that there was an auto box as well as the cvt. It's the auto cwp that I'm after. 2.9 ratio I'm told. Doing a rwd front engine special, using a bike engine, so want the long diff ratio, and keep the last couple of gears in the 'box and grind out the rest. This will give me fwd/rev/and a step up with 5th.
Nev
Volvorsport
posted on 28/3/11 at 07:46 PM Reply With Quote
all cvt mate........
not sure of the 2.9 diff fitting the manual box either .
sign up on v300 mania , youll find all you need on there .
posted on 28/3/11 at 07:58 PM Reply With Quote
Manual box was really huge too istr basically it was a version of the 140/240/260 box bolted to a diff unit.
The Variomatic was a laugh once encountered one that one of the half vee pulleys came off and rolled along the road over taking the car which was grinding to a halt.
