Author: Subject: WANTED Ford Crank Position Sensor for Omex ECU
SeanStone
posted on 12/4/11 at 08:18 PM Reply With Quote
Need to get hold of a crank position sensor. Standard ford should work for the Omex ECU
[Edited on 12/4/11 by SeanStone]
r1_pete
posted on 13/4/11 at 06:45 AM Reply With Quote
I'm sure I have one of the two mounting screw types, not the Zetec type, I'll find it when I get home tonight and post a pic up.
r1_pete
posted on 13/4/11 at 06:01 PM Reply With Quote
Any good, with plug an about 600mm lead
SeanStone
posted on 13/4/11 at 11:28 PM Reply With Quote
Looks to be suitable. I presume they all do the same thing?
r1_pete
posted on 15/4/11 at 06:49 AM Reply With Quote
I used it to bench test my megajolt, and it worked fine, in the car it will need shielded leads, or the existing ones shielding, but its an advantage having the connector and so much wire to work with.
U2U me if its any good, only looking for £10 posted..
