Macbeast
| posted on 3/5/11 at 06:55 AM |
Turn indicator cancelling cam thing
Came to reassemble the steering column and the black plastic indicator cancel bit is missing
Don't suppose anybody's got one spare ?
Edit to add - Sierra column
[Edited on 3/5/11 by Macbeast]
| posted on 3/5/11 at 06:58 AM |
Got mine from the local Ford dealer's spares department - cost me around 50p.
Macbeast
| posted on 3/5/11 at 04:47 PM |
They say that part's no longer on the system
Macbeast
| posted on 6/5/11 at 10:16 AM |
Still need this and IVA's on 17th. Even a loan would be better than nothing.
Pleeeeeeeeeeeeeese ??
blakep82
| posted on 6/5/11 at 10:23 AM |
annoying i know, but not a requirement for IVA (unless its essential to the indicators, like they won't work at all unless its there), sooo....
i shouldn't worry about it too much.
eg, its quite acceptable to have an on-off-on toggle switch, which is what i've got, and quite a few have a rocker switch
[Edited on 6/5/11 by blakep82]
________________________
Macbeast
| posted on 6/5/11 at 05:52 PM |
Ah OK Blake. Thanks very much.
I'll forget it for now then. Went out today for a tour of the scrapyards but the've all gone !! :-( T hey're all trendy winebars now
Macbeast
| posted on 9/5/11 at 04:08 PM |
Blast !!!
The indicator cancelling cam thing is also the retainer for the upper bearing and thrust washer.
So I do need one after all
blakep82
| posted on 9/5/11 at 04:17 PM |
could a steel replacement be made form some steel tube and a few bits of specially shaped steel pieces?
Macbeast
| posted on 9/5/11 at 05:33 PM |
I think that's the answer. Just a sort of collar, without worrying about the self-cancelling lobe.
blakep82
| posted on 9/5/11 at 05:42 PM |
i know the real ones are plastic, but i'm sure a steel pipe, or plastic pipe if you can get some easier
if steel, i'm sure you could weld tabs on for cancelling if you wanted to, if you can weld
