Author: Subject: Shopping List - Duratec stuff
karlak
posted on 19/5/11 at 09:13 AM Reply With Quote
Before I bite the bullet and buy the stuff new. The following is required for the next phase of engine change.
All for Duratec Rear wheel drive application in the MK Indy.
- Bellhousing, perfer cable, but Hydraulic also considered (price dependant)
- Sump
- Clutch / Pressure plate etc.
- Flywheel (lightened perhaps) or standard Fiesta ST150 please
- Oil Filter adapter
- Gasket sets.
That should get me to the position where I can moutn the engine.
Or anything else Duratec'ish you may have available
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
redeye
posted on 19/5/11 at 09:41 AM Reply With Quote
Duratec Raceline sump on ebay ending today
Caterham / Raceline wet sump for Ford Duratec | eBay UK
karlak
posted on 19/5/11 at 09:53 AM Reply With Quote
Yep, been watching that, but buggers keep bidding on it
redeye
posted on 19/5/11 at 10:15 AM Reply With Quote
yeah, damn fools.
Im in the process of fitting a duratec to my locost too at the moment.
the engine is still in bits at the moment tho. hoping to get it fitted into the car in the next couple of months tho.
what induction are you going for?
you might want to speak to Fastdan, he has fitted a duratec (2.3) and makes engine mounts and inlets manifolds for them.
I see you're actually quite close in Bedford.
Give me a shout if you need a hand at all.
FASTdan
posted on 19/5/11 at 12:19 PM Reply With Quote
Thanks Redeye, Simon has been in touch a few times
What are you doing for the alternator out of interest - both of you? Just looking at racelines stuff here:
http://www.raceline.co.uk/products/part_section.asp?SectionID=19&CategoryID=1
Am I right in thinking that is £150 for JUST an alternator, plus another £149 for a mounting kit?! I'm sure its all top spec stuff, but......ouch!
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
karlak
posted on 19/5/11 at 12:21 PM Reply With Quote
Yep, thats the way I read it - Ouch indeed
mcerd1
posted on 19/5/11 at 01:32 PM Reply With Quote
now if only there was someone who could make and sell mounting kits for a generic small altenator......
(nippondenso, kubota, 1.0 micra, or what ever most folk can get cheap these days....)
I ended up getting a new wee 45A one from H&H for a bit less than that - just got to work out how to mount it to my pinto now
[Edited on 19/5/2011 by mcerd1]
redeye
posted on 20/5/11 at 10:25 AM Reply With Quote
I was planning on using the standard ford focus pulley tensioner and mounting the alternator (probably a micra one) on the inlet side.
This seems to be the most straight forward approach.
I like to keep things simple, much like myself
Patrick
FASTdan
posted on 20/5/11 at 10:36 AM Reply With Quote
Patrick
Yes, thats what we did. Unfortunately I did not note the exact micra model we took the alternator from, therefore until I can identify it, even if I made a bracket I cannot specify 'this bracket suits an alternator from a micra xxxx'.
Saying that, it was a bubble micra and im fairly sure it will have been the 1.2 but who knows how many variations of that they did over the years.
