whitstella
| posted on 2/7/11 at 12:39 PM |
wanted brake calipers and disc's and pads
hi i have just been trying to fit a couple of brake calipers on my MK and they will not fit. i believe they are off a lotus elise so iam now after a
front set up calipers,disc's and pads. so if anybody has a set lying around drop me a line other than that what is the best set up to go
for?????
plus they have got to fit in my 15'' wheels.
cheers steve
[Edited on 2/7/11 by whitstella]
Hammerhead
| posted on 2/7/11 at 03:29 PM |
Hi Steve, they fit with the aluminium adaptors and some washers to space them out.
steve m
| posted on 2/7/11 at 11:54 PM |
your aluiminium spacer has a rather fetching wood grain effect !!
thefreak
| posted on 3/7/11 at 06:03 PM |
Is it because the radial mount bolts from the caliper interfere with the hub bolts, or is it the bracket will need a radius on it to allow the caliper
to sit in deeper? If it's the latter I may be able to help...
| posted on 3/7/11 at 06:57 PM |
Steve, you have U2U.......
Phil
thefreak
| posted on 3/7/11 at 08:16 PM |
Do you mind me asking what you paid for the calipers? As I've got a pair in the garage with pads..
