Author: Subject: 919 engine
brookie
posted on 9/9/11 at 10:58 AM Reply With Quote
919 engine
as above need full engine or the bottom end or i may just have the crank rods and pistons just let me now what u got
van cleef
posted on 9/9/11 at 05:51 PM Reply With Quote
I have a damaged engine from when the prop worked loose and tore the water pump off.
The block is cracked by the Generator casing but everything else is fine if you wanted to strip it.
It's a bare engine so no carbs,genny,starter motor.
doddy
posted on 9/9/11 at 06:29 PM Reply With Quote
i think i have a set of main cases if there any good may have the crank and other bits
https://www.ebay.co.uk/str/4x4wheels
jase380
posted on 9/9/11 at 07:58 PM Reply With Quote
This might be worth a punt mate, ebay item no 220846372531. would be a lot easier to drop a new motor in than rebuilding the fooked one.
brookie
posted on 10/9/11 at 12:39 PM Reply With Quote
hi jase think i going to look ti see what damsge it done to my yet give me some think to do over the winter lol
i can get a nearly new 1 from andy bates
brookie
posted on 13/9/11 at 05:15 PM Reply With Quote
right it now in bits and it looks like i need a crank shells and at least 2 rods so i dont now what to do now any clue what i should do lol
