Dangle_kt
| posted on 10/9/11 at 06:19 PM |
Wanted - engineering/workshop type task - happy to pay
Mate of mine has a scooter wheel that has a push fit bearing.
It needs reseating, as it no longer a push fit.
Not sure what is best, bigger bearing or some
Sort of repacking job... Anyway i imagine a lathe is needed, which we don't have.
Also need the end o the axles drilling an taping (hardened steel).
Anyone fancy earning a few quid to sort it?
snakebelly
| posted on 10/9/11 at 07:08 PM |
just asking but wouldnt a second had wheel with an unworn bearing housing be a better option? or is it super rare?
ashg
| posted on 10/9/11 at 07:11 PM |
how big is the wheel rim?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Dangle_kt
| posted on 10/9/11 at 09:00 PM |
12" rim, and no - not rare, but I imagine a bearing and some amature machining will be less than £70-80,which is how much a wheel would cost.
RAYLEE29
| posted on 11/9/11 at 08:36 AM |
how worn is it? if only a few thou you can use loctite bearing fit.
Ray
build diary1
http://picasaweb.google.com/raylee290/RoadsterPics#
build diary2
http://picasaweb.google.com/raylee290/KITCARPICS?authkey=Gv1sRgCI2AouyYgpuQmAE#
| posted on 11/9/11 at 09:54 AM |
Drilling and tapping hardened steel is not a simple job. Reclaiming the hub through either welding and machining back or boring out and sleeving will
likely make £70 look cheap for a new wheel.
If the bearing housing is not excessively worn then Loctite 660 may be your cheapest option.
