JAMSTER
| posted on 24/9/11 at 08:35 PM |
wtd 2.0 pinto
wtd 2.0 pinto engine pref 205 block and type 9 box if poss
snapper
| posted on 24/9/11 at 08:45 PM |
Just to help you widen your search any pinto is fine upto 6800rpm and 92 mm over bore.
The 205 block only gives benefit if you bore to 93mm or run a mad turbo motor.
If you are looking for a 205 make sure it's an injection version, better rods (7200 rpm) and much better inlet port flow.
To be honest if your not racing any pinto will go to 7500 here and there.
I eat to survive
I drink to forget
snakebelly
| posted on 25/9/11 at 07:21 AM |
Try looking in local shipyards..........
omega0684
| posted on 25/9/11 at 09:16 AM |
i;ve got a std 200 block you can have, come and get it
DixieTheKid
| posted on 25/9/11 at 03:00 PM |
These a cheap one on ebay Ford SOHC RWD Pinto 2L Trike / Kitcar / Project Engine + Twin Choke Weber | eBay i have an MT75
gearbox. Where are you?
COS IT'S Worth IT
DixieTheKid
| posted on 25/9/11 at 07:16 PM |
Also just come across this, think this is right up your street! 205 block as well! ford pinto engine spares or repairs 205 block rs
cosworth project | eBay
COS IT'S Worth IT
