po79
| posted on 12/10/11 at 05:03 PM |
Valve seat cutter for Pinto
Hi all,
I'm after a set of valve seat cutters for a big valve Pinto head. I'll be doing this by hand not machine.
Not to bothered what make but they need to be suitable for 38mm and 44.5mm valve seats.
I think these are normally 1.5 inch and 1 3/4 inch and with a 45 degree angle.
Let me know what you have, Cheers,
Poe.
snapper
| posted on 12/10/11 at 07:18 PM |
You'll want to do a 3 angle valve seat to squeeze the extra bhp out
I eat to survive
I drink to forget
omega0684
| posted on 12/10/11 at 09:45 PM |
i wouldn't bother doing it by hand, my local engine builder charged next to nothing to have my cut, phone around and see if you can save a lot
of time.
po79
| posted on 13/10/11 at 03:24 PM |
Thanks guys,
I could be wrong but you can get blades that fit into the 45 degree cutters that do a 3 angle job in one pass so it means I should only need one
cutting head for each valve instead of double sided cutters or several cutters for each angle.
I have phoned around and the cheapest quote has been £60 pounds per side so its £120 plus the vat. For not much more I could get my own cutters and
use them as many times as I like. I've read about the Neway cutters on different site and haven't found anyone having problems cutting
there seats by hand.
Time and patiance seems to be the key and a reasonable understanding of what your doing, I have all three so came to the decission that buying my own
makes far more sense.
Poe.
snapper
| posted on 13/10/11 at 04:35 PM |
Not seen three angles in one cutter, would have to be valve size specific.
I agree it would be nice to have a set and cut your own.
You will need to open out the throats/ports behind the seats before cutting the seats.
I eat to survive
I drink to forget
po79
| posted on 14/10/11 at 12:06 PM |
These are the cutters
3 angle Valve seat cutter blades #5 for Neway/5pack 3angle seat cut in one pass! | eBay
Like you say the throats would need to be openned first with my trusty die grinder before cutting the seats. I think before using the 3 way cutting
blades I would use a single cut blade first to get the seat near to where it needs to be. The 3 way blades do require a special tool to set them
up.
The one thing that is really good about having my own cutters would be that once I no longer require them I could sell them at a later date and get
some money back so not only would I save on the cost of getting someone else to cut the seats but I might even break even when if I sold the kit on
again.
Poe.
mcerd1
| posted on 14/10/11 at 01:22 PM |
quote: Originally posted by po79
I have phoned around and the cheapest quote has been £60 pounds per side so its £120 plus the vat. .
I got 3 angle seats and bronze guides done for only a tiny bit more than that a couple of years ago...
| posted on 14/10/11 at 07:25 PM |
Might be worth looking for a Black and Decker Vibrocentric bvalve seat cutter kit?? Make sure if you find one it has the stone dressing tool . May
well be cheaper than a Neway cutter and the stones can be dressed at required angles
po79
| posted on 17/10/11 at 03:37 PM |
I've only heard bad things about using the grinding stone type ones (for home use) every place I've read about this to have said the Neway
style cutters are heads and shoulders above the stone grinders.
Cheers for the info tho,
Poe.
