Author: Subject: Cossie engine
hector
posted on 11/11/11 at 09:20 PM Reply With Quote
Cossie engine
Would anybody have a spare cosworth engine laying around that they would like to sell?? Any condition will do!!
cheers Colin
needforspeed
posted on 11/11/11 at 10:32 PM Reply With Quote
205, 200?? standard or modded? have friends with allsorts of specs of engines if you let me know what your after i can ask, no engine specs are cheap these days tho even high milage standard 205 engines!
DixieTheKid
posted on 12/11/11 at 08:47 AM Reply With Quote
U2U sent
COS IT'S Worth IT
DixieTheKid
posted on 12/11/11 at 10:47 AM Reply With Quote
Just to clear up the 200 & 205 block thing. 205 was the early block, has less core plugs, 200 block was later on and stronger than the 205. This can also be long studded.
205 Block YBD - Sierra RS500
205 Block YBB - Sierra & Sapphire 2WD
200 Block YBJ - Sierra Sapphire/Escort 4WD
200 Block YBT - Escort 4WD
There was also YBG which had a green rocker cover, dont really know a lot about it. There is not a massive amount of difference between them machincally, the YBD was a bit special, i think you can safely knock that of off your wish list unless you have a lot of wonga!
I think ive got that little lot right.
COS IT'S Worth IT
l0rd
posted on 12/11/11 at 12:44 PM Reply With Quote
isn't the 205 stronger?
I think that everybody says it is.
I might be wrong though
hector
posted on 12/11/11 at 04:17 PM Reply With Quote
Ideally I would like a complete engine as i have just acquired a Mk1 escort rolling shelll which i plan to put it in!, I dont mind the rebuilding of it, also need a T5 box if poss!!
cheers
spiderman
posted on 12/11/11 at 04:44 PM Reply With Quote
I have a complete set up in a 4x4 Sierra Saphire, let me know what you want.
Spider
DixieTheKid
posted on 14/11/11 at 11:22 AM Reply With Quote
Originally posted by spiderman
Do you have the engine harness and ecu (is it l8)?
COS IT'S Worth IT
spiderman
posted on 14/11/11 at 12:57 PM Reply With Quote
Hi Dixie,
Yes I have got the set up still installed in the car so loom and ecu are there and I beleive all 4x4 Sapphire ecus are L8, though I stand to be corrected as I have not had eyes on to check it.
I have offered the whole package to "Hector" Motor/turbo/intercooler/silicon pipes/manifolds(inlet/exhaust)
/ecu/loom/injectors for £1750 .If he does not want the whole package I may split it and sell in parts for a better price. But I will give him the chance of first refusal.
Spider
DixieTheKid
posted on 14/11/11 at 01:04 PM Reply With Quote
Hi Dixie,
Fair shout, 1st refusal to Hector. Keep me posted. I might have the lot.
[Edited on 14/11/11 by DixieTheKid]
COS IT'S Worth IT
spiderman
posted on 14/11/11 at 01:12 PM Reply With Quote
Hi Dixie,
Will do.
Spider
hector
posted on 14/11/11 at 04:46 PM Reply With Quote
spiderman, PM sent
JAMSTER
posted on 15/11/11 at 01:20 PM Reply With Quote
found this any help
http://www.turbosport.co.uk/showthread.php?173138-2wd-cossy-engine-and-t5-gearbox
