Author: Subject: External bonnet catches
computid
posted on 17/12/11 at 06:43 PM Reply With Quote
Hi guys,
I need some new external bonnet catches for my minari. Im thinking of the clip kind but id be open to other suggestions.
Im trying to do this on a budget so anything cheap that you have lying around would be appreciated.
Oh, and it doesn't need to be IVA compliant.
Thanks!
blakep82
posted on 17/12/11 at 06:48 PM Reply With Quote
standard bonnet pins! not those nasty aero catches!
eBay Item
________________________
computid
posted on 17/12/11 at 07:09 PM Reply With Quote
I would use bonnet pins, but I want to put the catches on the side of the car, like this (in the red):
Otherwise the sides of the GRP bonnet stick out a bit.
blakep82
posted on 17/12/11 at 07:17 PM Reply With Quote
ah i see, in that case aero catches will work, and sit flush on the panel. they work in a way that the pin can enter the side of the catch. so pin sticks up from the panel underneath, and goes into the side of the catch.
here's a video of the installation options
http://www.youtube.com/watch?v=vBArgWgjTtM
computid
posted on 17/12/11 at 08:03 PM Reply With Quote
They do look rather good (if a little pricey!).
Ill order some tomorrow unless anyone else has a cheaper alternative?
RK
posted on 18/12/11 at 01:12 AM Reply With Quote
these work and are cheap. I've got them on my Deman 7.
BONNET BOOT HOOKS WESTFIELD CATERHAM 7 DAX LOCOST COBRA | eBay
But if you have something in mind, and it won't put you in the poor house, you have to have something that looks good to you.
[Edited on 18/12/11 by RK]
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 18/12/11 at 08:46 AM Reply With Quote
IVA Bonnet catches RobinHood Catherham Westfield kitcar | eBay
