Author: Subject: Wanted zetec lifting brackets
mazie
posted on 20/1/12 at 10:46 PM Reply With Quote
Has anyone got any of brackets I could borrow? I've looked round a breakers and none of the engines had them attached.
If not I'll just have to make some up but would rather save myself the time. Do I really need them? Surely chain bolted in will safice?
designer
posted on 20/1/12 at 11:00 PM Reply With Quote
I use thick rope, or a couple of straps around the engine.
mazie
posted on 20/1/12 at 11:10 PM Reply With Quote
Around the crank and sump?
paulf
posted on 20/1/12 at 11:26 PM Reply With Quote
If the manifolds are off I Just secure a length of chain using a couple of inlet and exhaust studs and some large washers.It is better to support from the top of the engine as the weight then keeps it steady.
Paul
AndyW
posted on 21/1/12 at 08:52 AM Reply With Quote
I have the brackets but Im a bot too far away, unless you want me to post them on Monday?? u2u if needed
mazie
posted on 21/1/12 at 09:57 AM Reply With Quote
Hi andy thanks for the reply, I'm trying a breakers later who reckons he may have a pair, failing that I'll U2u yourself later.
We're they needed in your opinion?
