Author: Subject: Wanted Propshaft
cfc999
posted on 23/2/12 at 09:54 PM Reply With Quote
Wanted Propshaft
Need a propshaft for my xflow powered Striker. I'm running a live (english) axle and needs to be 645mm long.
Chris
A1
posted on 24/2/12 at 02:59 AM Reply With Quote
might be able to help you there... ill check tomorrow and let you know
will121
posted on 24/2/12 at 07:30 AM Reply With Quote
Are you are running a 4 speed gear box? If so I will measure one I have in garage
cfc999
posted on 24/2/12 at 08:36 AM Reply With Quote
Yes I'm running a 4 speed box to a english axle.
Cheers Chris
cfc999
posted on 24/2/12 at 08:43 AM Reply With Quote
Thanks for that. Keep me posted.
Chris
TimEllershaw
posted on 24/2/12 at 09:55 AM Reply With Quote
Chris
Would this be of use ?
May be a bit too long ?
From a Ford Type 3 gearbox ( 7/8" x 20 spline ) to English diff in a Westfield casing.
Propshaft
Propshaft
Prop End
Prop End
Prop end
Prop end
http://www.teenagecancertrust.org/
cfc999
posted on 24/2/12 at 10:58 AM Reply With Quote
Needs to fit between a xflow 4 speed (thinks its called a type 2) and a english axle. Measured betwween the two and its 645mm.
Chris
will121
posted on 24/2/12 at 04:57 PM Reply With Quote
just measure my spare one and its overall 960mm long, was used with a 4 speed box with 16 spine end on it, may be of use if correct uj's if you want to modify and shorten it?
cfc999
posted on 27/2/12 at 10:41 AM Reply With Quote
Thanks for the offer. Might be of some use. What axle was the westfiled running. Also any idea how much you want for it and what would it cost to post to Lancshire.
Chris
will121
posted on 27/2/12 at 09:00 PM Reply With Quote
im sure it was a standard escort english axle, but ive taken some measurements on the first photo if you want to check it fits your axle, UJ's feel good and both have grease nipples
after £25 + postage which is about £8 for a 3-5day parcel
cfc999
posted on 27/2/12 at 09:39 PM Reply With Quote
Thanks for the info. Will check and see how much its going to cost to shortened and get back to you.
Chris
[Edited on 27/2/12 by cfc999]
