matty h
| posted on 13/3/12 at 07:45 PM |
Alloy wheels grit blasting
Anyone have acsess to a grit blaster to do a set of 15 inch mgf alloys local to scunthorpe north lincolnshire.
Thanks Matty
designer
| posted on 13/3/12 at 10:57 PM |
There should be a local blaster near to you, they are cheap enough and you have some guarantee about any damage to the rims.
wilkingj
| posted on 14/3/12 at 10:21 AM |
These people are just off the A1 at Huntingdon. OK not in Lincolnshire, but an easy drive to get there (A1).
I know two people who have used them and both did so after a reccomendation.
Not used them myself, but have heard good things.
http://www.wheelgenie.co.uk/
Best Regards
Geoff
http://www.v8viento.co.uk
afj
| posted on 14/3/12 at 11:47 AM |
wheel genie did mine top job if you use them you can drop the wheels at mine in peterborough and ill take them as i work 1 mile from wheel
genie
[Edited on 14/3/12 by afj]
eerrrrrrrrrrrrrrrr
