ReMan
posted on 20/4/12 at 09:05 PM |
Prop Angles with Reverse box
Slow progress but hope to get some steel to malke a mount for the reverse box in the morning, else we'ere never going to get to Stoneleigh ![](/images//smilies/sad.gif)
Now the centre bearing is gone and replaced by the reverse to keep everthing even, I plan to put the reverse box on a slight angle so that there is
roughly the same angle on the engine to reverse and then reverse to the diff.
Bad picture below trying to illustrate what I mean
Any problems with this?
![](/galpreviews/IMG_1992s PROP.JPG) ![PROPANLES](/gallery/IMG_1992s PROP.JPG) PROPANLES
[Edited on 20/4/12 by ReMan]
www.plusnine.co.uk
twybrow
posted on 20/4/12 at 09:53 PM |
Bailey Morris stated to me that as long as you are no more than 7degrees out of true, you will be ok. Remember, that is vertically, and horizontally
too!
R1_striker
posted on 23/4/12 at 06:00 PM |
alway good to run the joint on an angle so that all of the joint is being moved and worked
