Author: Subject: Cortina Prop Shaft
Jeffers_S13
posted on 31/8/04 at 04:09 PM Reply With Quote
Cortina Prop Shaft
I actually only need the flange from the diff end to make a hybrid prop.
Or else does anyone know any other flanges/prop shafts I could use as donor for this ?
James
Mark Allanson
posted on 31/8/04 at 05:52 PM Reply With Quote
Most fords have the same flange at the diff end. I have a sierra one mated to a capri axle which is very similar to the cortina axle, just a little narrower and without the 'ears'
posted on 31/8/04 at 06:38 PM Reply With Quote
Some have round ends and some have squarish ones but the hole spacing is same. Mine was lying on the scrapyard floor and allegedly came from a Transit.
Jeffers_S13
posted on 1/9/04 at 06:52 AM Reply With Quote
Thanks guys.
