HowardB
| posted on 8/6/12 at 05:39 PM |
ford zetec - water sensor - plug required
As per title, I am after the plug that fits the sensor as shown in the pictures.
  Sensor_socket
  sensor_socket_B
It is the Ford ECU water sensor plug from a late zetec as I understand it.
beer tokens are available,....
thanks
Howard
r1_pete
| posted on 8/6/12 at 05:58 PM |
I used a couple of minature 'spade' type connectors, because I couldn't get a suitable plug.
[Edited on 8/6/12 by r1_pete]
AntonUK
| posted on 8/6/12 at 06:06 PM |
ditto, i was willing so spend the extra ££ on the proper connectors but I couldnt get any.
Build Photos Here
big_wasa
| posted on 8/6/12 at 06:10 PM |
I will have a look in the mornning as I will be loom building this weekend if the weather is crap.
HowardB
| posted on 8/6/12 at 06:23 PM |
thanks every one, I had thought of using an injector plug as the inner is similar, but a lot further down a different shape hole,...
appreciate everyones efforts
fingers crossed
Howard
AndyW
| posted on 8/6/12 at 08:41 PM |
If warren doesnt have one I will have a look as I still have one loom left, minus a few plugs.
Also, Warren, if you need any plugs let me know and I will see what I have as still have most of one loom and an injector loom here
Dusty
| posted on 9/6/12 at 01:18 AM |
Ford doctors the male and female plastic of their plugs to make fitting easier. The 'fins' on the sender only allow the correct loom
connection to fit. If the fins are cut off, not affecting the senders function or locking mechanism then many ford two pin female plugs will fit. Like
so.
[img]
  DescriptionPlug
[/img]
HowardB
| posted on 9/6/12 at 04:47 AM |
so.
[img]
  DescriptionPlug
[/img]
thanks for that, just what I was thinking, but the injector plugs I have are shallow, and this is deeper. If there is nothing out there, then
I'll make something with an old plug and some epoxy.
Thanks again everyone, that is why I like it here so much
Howard
big_wasa
| posted on 9/6/12 at 06:37 AM |
Ive got one spare of them out of a box full of plugs.
u2 me your address and I will stick it in the post one day in the week.
big_wasa
| posted on 9/6/12 at 06:41 AM |
Cheers Andy, I am making one upto sell and then thats it for the zetec from me.
wombat
| posted on 9/6/12 at 07:29 AM |
U2u sent wasa
HowardB
| posted on 9/6/12 at 07:36 AM |
I still have a zetec injection loom, and with one or two other plugs, but none like the one I need, I am sure that might be of some use to some
one.
Howard
HowardB
| posted on 9/6/12 at 10:51 AM |
now sorted
thank you all, this is the best forum in the whole web!!
Howard
Howard
