Author: Subject: FS: Akito Dessert XL Motorcycle Jacket - SOLD
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 30/8/12 at 07:01 PM Reply With Quote
Akito Dessert Motorcycle jacket with inner liner for cold mornings, Includes shoulder and elbow protection. This cost me £150 and I have only warn it a handful of times. Very good condition, no scuffs or tears. £45 + P&P
Size XL
This is the official commentary:
- Outer shell constructed from 600D Polyester
- Interior liner constructed from 100% Polyamide
- Reinforcements at all impact zones using abrasion resistant AIRTENA® KNOX® CE approved protectors at shoulders and elbows
- Protector pocket provided to retrofit Knox Part 65 Back Protector
- Windproof, waterproof and breathable 3 in 1 Modular Skin System separate detachable waterproof membrane & thermo-lining (80% Polyamide / 20% Polyester)
- ARD Airvent- ventilation system on arms, chest and back
- Adjustable arm straps using tunnel system
- Adjustable waist belt
- Waterproof external pockets
- LUMIDEX® inserts for improved visibility
- Comfort collar, document pocket and waterproof front zippers
- 3M® daylight reflective insert on back
- Long and short connection zipper
[Edited on 30/8/12 by Barkalarr]
[Edited on 1/9/12 by Barkalarr]
spiderman
posted on 30/8/12 at 07:24 PM Reply With Quote
Putting the size of it in the listing might help.
Spider
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 30/8/12 at 07:27 PM Reply With Quote
It says it in the title, but I have now added XL to the listing.
Thanks.
sdh2903
posted on 31/8/12 at 04:24 PM Reply With Quote
Is the armour removable or fixed? Quite fancy this for kit driving if it can be removed.
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 1/9/12 at 10:55 AM Reply With Quote
Sorry - I've had a good look at the jacket and the elbow and shoulder protection is sewn into the jacket - you can't take it out without cutting it out.
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 1/9/12 at 01:02 PM Reply With Quote
Ok, I'm an idiot - yes you can take the padding out - there is velcro pockets for the padding on the inside of the jacket (not the outside where I looked before)
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 1/9/12 at 04:29 PM Reply With Quote
Sold
ed1801
posted on 21/9/12 at 04:07 PM Reply With Quote
Received quickly and as described... top seller
