Author: Subject: pinto woodruff key
Craigorypeck
posted on 17/10/12 at 10:37 PM Reply With Quote
pinto woodruff key
mines has gone missing, it was worn anyway but what size is it? loads on ebay for a quid or so but does anyone have the answer? Thanks
Craigorypeck
posted on 18/10/12 at 06:33 AM Reply With Quote
its the outer crank pulley one not the one under the timing belt cog
mcerd1
posted on 18/10/12 at 06:50 AM Reply With Quote
I thought the pinto only had one key for both ???
all 4 of my pinto's had a single long key (cossie cranks have two small keys instead)
like this: http://www.burtonpower.com/parts-by-fitment-type/parts-by-engine-ford/ford-sohc-pinto/woodruff-key-crank-gear-pulley-combined-sohc-pinto-ft585.html />
[Edited on 18/10/2012 by mcerd1]
snapper
posted on 18/10/12 at 07:13 AM Reply With Quote
Yes just one long woodruf key
I eat to survive
I drink to forget
Craigorypeck
posted on 18/10/12 at 09:39 AM Reply With Quote
Silly me its a cossie crank, 2 separate keys. Outer pulley had 5 degrees of play so needs a new one. Burtons have them but postage to NI leave little change from a tenner.. yes I'm a tight hole! Cheers!
mcerd1
posted on 18/10/12 at 11:10 AM Reply With Quote
I got mine from burtons (cossie crank) I can measure them at the weekend if need be
btw what pulley are you using ?
I'm only asking as the cossie crank has a bit longer nose than the pinto one (5 or 8mm can't remember exactly off the top of my head) so you'd need a spacer to get the smaller lighter pinto pulleys to bolt up tight
Craigorypeck
posted on 18/10/12 at 06:11 PM Reply With Quote
its a serpentine cosworth pulley so fits as it should.. thanks
Craigorypeck
posted on 18/10/12 at 07:42 PM Reply With Quote
got sorted this eve, thanks
