unijacko67
posted on 29/10/12 at 11:06 PM |
WTD Honda K24 Crankshaft
I am after a few bits for a honda engine rebuild.
1. Honda K24 Crankshaft (4 cylinder) Acura TSX or UK equivalent, may be Accord.
2. Honda H22A Rods & Pistons, from Prelude engine.
3. Honda s2000 oil jet bolts, new type.
http://www.kittenkitcar.co.uk
me!
posted on 30/10/12 at 07:31 AM |
2.4L S2000 engine?
unijacko67
posted on 30/10/12 at 08:13 PM |
S2400
Well that’s the aim, I have a totally standard s2000 engine which I intend to get my build up and running with, and as an ongoing project I will be
building an s2400 if I can locate some cheap parts. I’ve just bought a spare s2000 engine so on the lookout for the rest. I may buy new pistons or at
the very least a set of rings, but need my block horning out and understand it’s not the easiest job as the bores are coated.
unijacko67
posted on 30/11/12 at 07:19 PM |
Still after K24 crankshaft. Got new pistons & rings, 87.25 and found machine shop who can bore FRM, fingers crossed anyway. He can Hone as he
bought the correct stones and has done a sucsessful test, I'm just unsure if you can hone from 87mm to 87.25 or whether it may need a re-bore
first. Anyway I will leave that to him.
![](/galpreviews/Pistons 87.25.jpg) ![Description](/gallery/Pistons 87.25.jpg) Description
