Jeffers_S13
posted on 20/9/04 at 11:11 AM |
Ford 9" drum brake parts needed
Is there anyone who can help me ?
I have bought as many new brake parts as possible for a kit car Im building with Mk5 Cortina rear axle. However its not possible to buy the ratchety
bits for the self adjusting mechanism or the adjuster bar that runs across the top.
Can anyone sell me a set of these ? I will also need the spring clips that hold the top ratchet to the shoe.
Also, could someone if possible send me a pic of the whole set-up installed with the drum removed, I bought a brand new set of springs but they dont
seem to look the same as the ones in the Haynes manual.
Many thanks
James
ASH3
posted on 20/9/04 at 05:08 PM |
Suppose you tried you local Ford dealer
if not try them again but this time get them to look on the Ford Obsolete file.
All dealers have access to it, amazin what
can be found on it + very cheap too dont
let them tell you different!!!
Good Luck
